Dension ICE>link plus in 2005 Renault Megane
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by grantsteve, Apr 18, 2005.
  1. grantsteve
    grantsteve
    Apr 17, 2005
    1,451
    Birmingham
    +223
    I'm having trouble with Dension's ICE>link plus in my 2005 Megane. Connected it up with the Connects2 adaptor. Headunit recognises that there is a changer connected but either gets stuck checking for CD's or tells me there are no CD's in.
    Dension reckon its a problem with the new Tuner List headunits in some 2005 models, and are 'developing a solution'!
    Anyone had a similar problem and found a way round it? Or does anyone have any idea's for an alternative solution? I want a direct connection - no messing about with FM transmitters.
    :confused:
  2. Sciamano
    Sciamano
    If your Tuner List radio is like mine, when you shuffle through the "Sources" you will find also the item "AUX" (you actually have to enable this in the Expert mode menu).
    If it shows AUX, then the IceLink is not compatible with the radio.
    It's a problem with the new (11/2004 and later) Tuner List radios.
    I have the same problem as you. The only way I found to connect my iPod to my Megane radio is using a cable that converts and enables this AUXiliary inputs. But you can't connect the IceLink, and can't control the iPod.
    It's just like having a "line in" input.
    Better than nothing, though.
    HTH
  3. Member 7321
    Member 7321
    Mar 28, 2001
    208
    Heathrow/Warrington
    +19
    A little more information for you:
    There are three different models of Tuner List head unit from VDO and it is very difficult to tell which one is which. The Dension Ice Link>Plus + Connects2 adaptor will only work with one of the head units.
    Dension are currently developing with Renault an Ice Link>Plus that will work with all versions of the Tuner List head unit directly on the CD Autochanger port so no need for a Connects 2 interface. This should be available within the next 4-8 weeks as it is just going through final testing now.
    HTH
    Ultra238a
  4. Sciamano
    Sciamano
    Is this some sort of Ice-Link Lite for Renault?
    That would be interesting...
  5. thunt
    thunt
    Do you know what cable is required to connect into the 'Aux in' on a Megane 2005 stereo. Renault don't know and the stereo manufacturer refer me back to Renault.
    Tim
  6. Sciamano
    Sciamano
    I don't know the schematics of the cable. I've bought it at www.bortesi.it
    The guy speaks english and is very helpful. I suggest you ask him for assistance.
    HTH
    Luca
