Dension ICE>link plus in 2005 Renault Megane
Discussion in 'Headphones, Earphones & Portable Music' started by grantsteve, Apr 18, 2005.
  1. grantsteve
    grantsteve
    Apr 17, 2005
    1,453
    Birmingham
    +223
    I'm having trouble with Dension's ICE>link plus in my 2005 Megane. Connected it up with the Connects2 adaptor. Headunit recognises that there is a changer connected but either gets stuck checking for CD's or tells me there are no CD's in.
    Dension reckon its a problem with the new Tuner List headunits in some 2005 models, and are 'developing a solution'!
    Anyone had a similar problem and found a way round it? Or does anyone have any idea's for an alternative solution? I want a direct connection - no messing about with FM transmitters.
    :confused:
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
    No solution, just envy that there is a product for your car!!
    I have a 2004 Accord and can't find anything to link with the head unit anywhere. Dension are supposed to be coming out with a solution, but I am still waiting!
    There are systems which may work with my Accord, but I am reluctant to take the dash apart only to find that there is a lack of compatibility.
