M
montyfcu
Search through the ICE link category and couldnt find anything re this subject.
I've just had the ICE link plus fitted to my 03 clio factory fitted radio. The company have sent me an update as apparently some kits need updating before they work correctly.
I have d/l this update to a playlist and ran it but still have terrible crackling noises on a lot of tunes, listen to rock/indie so most songs sound terrible!
I have turned the EQ off on ipod, and soundcheck on. Anyone had same problem or any ideas?
Amy
Amy
