DenonAVR3803 & PioneerVSX2011 into 4 & 6 ohm ??
Discussion in 'AV Receivers & Amplifiers' started by Merritt, Mar 17, 2003.
Tags:
  1. Merritt
    Merritt
    Feb 5, 2003
    262
    Hampshire
    Hi Guys,
    Im currently considering either of these amps but there is a large likelihood that my centre channel speaker will only be 6ohm and the rears are likely to be 4ohm only. Will this prove a problem to either the Denon AVR3803 or Pioneer VSX D2011?
    Steve
  2. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    I would suggest 6 ohms is borderline for the 2011 and 4 Ohm is a definite no-no. It is not designed for speakers below 6 Ohm nominal impedence.
    The 3803 should be fine. You might want to have a look at the Sony 333ES and 555ES which have a switch on the back for 4 or 8 Ohm speakers.
  3. Robert
    Robert
    Check out the Nad Range. The Nad T762 is well specified and goes down to 4 ohms load on each channel without overheating or giving any trouble to the Power Amps.
  4. Merritt
    Merritt
    Feb 5, 2003
    262
    Hampshire
    Daneel - are you sure that the AVR3803 can manage 4ohms? I just took a look at the spec sheet on the Denon home page and can only find power references at 6ohms?
    How can I find out for sure if either of these amps will handle 4 or 6 ohms?
    Steve
  5. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    Try it for yourself, ask your dealer or email Denon.
    I have been given the impression in previous threads asking pretty much the same thing that you have that the 3803 will handle 4 Ohm speakers but no, I am not sure.
  6. Relay
    Relay
    Feb 22, 2001
    38
    My 2011 happily drives Kef 60s (4ohms) as rears and Tannoy R1s (8ohms) or Castle Harlechs (8ohms) at the front.
  7. Robert
    Robert
    The power amps will be on a workout as more power is required to Drive a set of speakers. This could result in early faults within the unit itself due to overheating etc.
  8. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    No problems at all with my Pioneer 2011 driving 6 ohm Monitor Audio silvers.
  9. EvilMudge
    EvilMudge
    Big confusion as to which will drive lower impedance speakers better. The Pioneer has a more sensitive protection circuit than the 3802 model, but probably has greater actual power (it's a bit of a darkhorse in power terms). Both are supposed to be pretty good at driving low impedance loads, as far as one box systems go.
