DenonAVR 3802 help needed
Discussion in 'AV Receivers & Amplifiers' started by petev, Mar 11, 2006.
Tags:
  1. petev
    petev
    I am hoping someone can help me. I have a 3802 amp and i am having trouble with it. I have just come to play a dvd and I cannot get any voices out unless I turn the volume very high. It has prev been ok, no-one in the house is admitting to changing anything. I have tested the speakers and they work ok, when I play normal tele through all the speakers it is fine.
    :lease: :lease: help
    Pete
  2. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    sounds busted
  3. hoppaz
    hoppaz
    Oct 1, 2005
    1,916
    +225
    Check that the cable carrying sound to the amp is plugged in correctly at the amp and dvd player. Also check that the imput in the amp settings is correct ie. optical or coaxial etc. Alternatively if you are using a optical cable to supply the sound, try changing it with another socket.
