Denon3801+atomic
Discussion in 'AV Receivers & Amplifiers' started by andy21, May 6, 2001.
Tags:
  1. andy21
    andy21
    hi, just purchased a denon 3801(very nice) and the eltax atomic system. I have a very strange problem. When i turn off the subwoofer there is an almighty thud from it. This only happens when it is connected to the denon. If i unplug lead to sub from dennon it doesnt do it. Why does it do this and can it damage the sub.???????
  2. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    This sometimes happens to mine and it stops when I turn the volume on the amp down befor switching the sub off. Hope this helps.
  3. daiwa
    daiwa
    Dec 2, 2000
    11
    wales
    Hello. I have the previous model EAS20 Eltax Sub. and exactly the same occurs when switching off. I also turn the volume down before switching off.
  4. andy21
    andy21
    ok thanks i will try this later today
  5. andy21
    andy21
    hi
    yes this stops it but i think it only stops the noise not the actual fault, any ideas what it might be, possible fault with sub? or just interferance in the system???
  6. andy21
    andy21
    oops, sorry didnt sort it. Its just done it again. This time i turned down denon, powered off and unplugged denon. Then turned off sub BANG!! big thud again. Do you think there could be a fault with the sub??? Also any other ideas of how to stop it?
