denon
Discussion in 'AV Receivers & Amplifiers' started by madliam, Jul 2, 2005.
Tags:
  1. madliam
    madliam
    Apr 29, 2005
    34
    :lease: :lease: :lease: hi i got a problem with a hummmmmmmmmm from my sub which is a kef psw3000
    wich is attached to a denon avc-a11sr please help
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,464
    United Kingdom
    +1,936
    Does the sub hum even if it's not connected to the Denon?
  3. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Has the sub got a metal earth pin? or is it plastic? It sounds like an earthing problem, depending on the pin on the sub try changing it from plastic to metal or vice versa.
