denon ,yamaha
Discussion in 'AV Receivers & Amplifiers' started by abhijit15, Aug 6, 2006.
Tags:
  1. abhijit15
    abhijit15
    My name is Abhijit from india
    will give me advice about buy amp ?
    i am trying to purches YAMAHA RXV-1600 but my friends told me to that Denon is better than yamaha.
    now i get double minded so i thought to purches Denon-2106 as a prosessor and use Yamaha-1600 as a AMP so please tell me is it right move or not ?
    I am depent on ur advice
  2. PeteD64
    PeteD64
    Apr 9, 2006
    692
    28
    Southsea
    +48
    If you read through the threads in here you'll find fans of both Yamaha & Denon. I can't really say which is better, some people prefer the sound of one over the other.
    What you really need to do is listen to both & decide which you think is best.
    I wouldn't advise buying both & using one as a processor & the other as an amp. If you can afford both you would be be better spending it on all a single more expensive product like the Denon 3806.
  3. abhijit15
    abhijit15
    ok
    but when we play dvd 3806 is better or yamaha1600?
  4. abhijit15
    abhijit15
    THANK U
  5. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Yamaha RXV2600 (upscaling, upconversion) / Denon 4306 (upscaling, ethernet interface for media streaming) is a better choice
  6. PeteD64
    PeteD64
    Apr 9, 2006
    692
    28
    Southsea
    +48
    Not sure. I'm not too familiar with the Yamaha range & I thought the 1600 was more of a budget amp until I saw the price/specs just now. They could be similar quality.
    If you are not in a hurry to buy now the 1700 & 2700 are coming soon.
    http://www.audioholics.com/news/pressreleases/YamahaRXV2700receiver.php
    Just don't buy one each of Denon & Yamaha amps unless you want to try them both & then sell one. It will be a waste to use the processor from one & the power amps from the other.
  7. abhijit15
    abhijit15
    thank u peteD64
