Denon X4300H - Not showing any active speakers
sago
Hi All
The system was working fine. Not sure what has gone wrong. The Amp is showing no Active speakers on the display at the front. Usually rectangles with individual speaker codes in them. Ive tried all sources including Spotify and nothing is playing any sounds. Just at the top of where the active speakers usually are is displayed out.
What I've tried.
1) reset the system
2) done audessy setup and makes all the popping sounds for the tests. (So I know the speakers are working and connected correctly)
Another thing does not show any output on the projector on any of the outputs.
Any help will be appreciated. Not sure what has been updated or if anyone else has had this issue any help will be appreciated.
Thanks all.
Dobbyisfree
I recommend that you post this on the owner's thread :)
Podcast: The Best TVs of 2021, plus our favourite & memorable reviews of the year
