Denon x4200 and android tablet.
Discussion in 'AV Receivers & Amplifiers' started by Spanishal, Mar 10, 2017.
  1. Spanishal
    Spanishal
    May 19, 2014
    2
    Hi Guys,
    This is my first post so go easy!!
    My question;
    How do I connect my Android tablet (using the hmdi mini output) to the Denon X4200W.
    I want to watch downloaded movies on my Epson projector and have the sound coming out of the floorstanders.
    Thanks in advance,
    Al.
  2. dante01
    dante01
    Mar 5, 2009
    45,245
    +10,651
    Use a Mini HDMI type C to HDMI type A cable if dealing with a mini output on the tablet or look for a Micro type D HDMI to HDMI type A cable if the output is a HDMI Micro output.
    usbandfirewirecables.blogspot.co.uk/2…
  3. Spanishal
    Spanishal
    May 19, 2014
    2
    Cheers.
    Ive got all the cables I just dont know how to connect them correctly to get sound through the Denon and a picture from the Epson.
  4. dante01
    dante01
    Mar 5, 2009
    45,245
    +10,651
    The receiver's manual will explain the inputs to you. I'm not sure what you are having difficulty with? You'd connect the source's outputs to the receiver's inputs and you'd connect a display and or PJ to the receiver HDMI output(s). The receiver deals with the audio sourced from the source while passing through the video to the devices connected to its Hmain and second HDMI outputs. The third output is a second HDMI zpne output.
