junkie69
Hi Folks,
Long time reader - first time poster.
Appologies for the long post in advance.
I have my eye on the Denon AVR-x2700H.
However, I note that the headphones can't be left plugged in if I want to listen through speakers also.
Manual states that:
My current setup (old amp) has physical switches for A and B zones, and the headphones work irrespective of the a and b switches. (i.e. on or off.)
This worked well for me, beacuse it allowed me to leave the wireless headphones plugged in to the headphone jack. (The headphones have separate on/off and volumen switches.)
I also have Tannoy 637's setup with bi-amp as the main speakers.
X2700H manual shows I should be able to use a 5.1, with bi-amp and still have the use of Pre-out RCA Zone 2
Speaker configuration and “Amp Assign” settings AVR-X2700H
My question is, will the Zone 2 pre-out signal work similar to the headphone plug?
I have heard that sometimes the pre-out signal volume is way too low, and hence unusable for wireless headphones.
The headphones do have volume switches, however if you push them to a higher volume, there is noticble static.
Current setup I have, the amp volume also adjusts headphone volume.
Thanks for taking the time to read, and I hope I have explained the situation well enough.
Manual states that:
When the headphones are plugged into this jack, audio will no longer be output from the connected speakers or from the PRE OUT connectors.
Main Zone: 5.1-channel (bi-amp connection for front speaker)
Zone 2: 2-channel (Pre-out)
