sibuns
Hello.
I have one problem with tv sound using the denon avr x1400B. So my setup is like this:
I have a philips tv which is connected to receiver through ARC hdmi connection. It was working fine. I turn on tv then the receiver turned on and sound was ok. I changed my subscription with my ISP and i got an adroind tv box called EON BOX. So i put a Signal cable into my box and connect HDMI to denon Cbl port. The tv is still connected to receiver via ARC hdmi. When i turn my new tv box on, the tv turns on automatically then i just turn on denon and everything is ok. (TV source is set to HDMI 1). If i put an usb with a movie on it in my tv and select the source on my tv to USB the movie strats playing, but there is no sound on my speakers. If i turn the hdmi sound to tv sound on my tv, the sound is comming from the TV. When i change back to HDMI, there is not sound on my speakers connected to denon.
Can you help me set up this correctly ?
Thanks for help and best regards.
