Denon V Yamaha
Discussion in 'AV Receivers & Amplifiers' started by Mwillo, Feb 15, 2002.
Tags:
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Could someone please help me, I have a limited budget of £350 pounds to buy Home Cinema Receiver which can be used with tv, video, DVD, Sky Digital and various games consoles I have been looking round for a couple of months trying to decide and have now got it down to two choices both are available from richer sounds and are within my price range they are the Denon 1802 and the Yamaha RXV620RDS. looking through various reviews they both come out very well. And to be honest I am more confused now than when i first started looking.
    Please hlp I jumped into buying a sony pro logic amp about 3 years ago and regrettd it so I dont want to make the same mistake again.
    If there is a better amp then please give me your opinion.
  2. russraff
    russraff
    Aug 1, 2000
    2,452
    Newcastle
    +78
    Personally, I would get the Yamaha. The company still seems to produce excellent budget kit, despite loosing ground at the high end.
    Russell
  3. Guest
    Im a big yammaha fan and own their gear myself (A1) but id say get the 1802.
    Ive heard good things about it and it does have pro logic II
    But really the yamaha is good and will not disapoint, but denon as the edge.
  4. WSC
    WSC
    Nov 1, 2001
    60
    Go and listen to both of them side by side. IMHO I think that the Denon has a clearer sound than the Yamaha. The Yamaha had more hiss on the rear channels than the Denon - but maybe I'm just being sensitive after having had a Yamaha 420 for a few weeks before swapping it for a Marantz 5200 (which is also in your price range and a good amp).
    Rgds
  5. jezzpalmer
    jezzpalmer
    Jan 27, 2002
    22
    I just got a Yamaha RX-V800RDS for £370 delivered from Richer Sounds & I'm more than happy with it.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I only say one word (even I say it three times): listen, listen, listen
    Nobody (not we or any review) can tell you what you like, you need to listen yourself and decide, only then you can be sure you will be satisfied.
