DENON UD-M30; help please
Discussion in 'AV Receivers & Amplifiers' started by tonydavies, Apr 8, 2005.
Tags:
  1. tonydavies
    tonydavies
    :lease:
    Can anyone offer me advice on the following basic fault please? When mains is applied the On-Standby switch seems to work OK in that it changes from red to greeen when pressed and vice-versa. However, the display panel doesn't light up and no controls work. A possible power supply fault maybe but any advice would be appreciated. As a last resort does anyone have access to circuit diagram etc.?
    Many thanks.
