Denon ud-m3
Discussion in 'AV Receivers & Amplifiers' started by mauvedipstick15, Mar 12, 2006.
Tags:
  1. mauvedipstick15
    mauvedipstick15
    Feb 25, 2006
    496
    liverpool
    +18
    My denon ud m3 will not turn volume up on dial but is ok on remote will turn up and down anyone got any ideas please!!!
  2. astraturf
    astraturf
    Mar 8, 2006
    4
    Is that the funny little all in one midi/micro thingy.
  3. mauvedipstick15
    mauvedipstick15
    Feb 25, 2006
    496
    liverpool
    +18
    Thats the one its about the size of a cyrus box
  4. joaopaulo
    joaopaulo
    It´s not normal, take it back to the store... :nono:
  5. Ian_S
    Ian_S
    Dec 29, 2005
    7,163
    163
    +2,198
    It's a common fault, the volume control on the unit needs replacing, I have one with the exact same problem. As the remote works I haven't bothered getting it repaired as the unit is quite old and it would probably cost more than it's worth :)
  6. mauvedipstick15
    mauvedipstick15
    Feb 25, 2006
    496
    liverpool
    +18
    Thanks for that mines a couple of years old thought it might have been the elastic band snapped or something?
