Question Denon, stuck cd drawer help
Discussion in 'Hi-Fi Stereo Systems & Separates' started by pete1866, Jul 26, 2018.
Tags:
  1. pete1866
    pete1866
    Oct 25, 2004
    905
    28
    +53
    I have a Denon DM39 which has a cd stuck in the drawer.
    I have spoke to Denon and tried to reset it.
    When I push the open button there is no noise. I have had the top off and cannot force it out.
    There are no repair shops at all in my local town, so wonder if anyone has any ideas.
    At worse I just want my cd back for now.
    Thanks for any replies.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    Can you post a picture of the unit with the top off?
  3. larkone
    larkone
    Apr 21, 2006
    4,384
    134
    North Essex
    +1,254
    A replacement CD will be cheaper than a repair. It is likely to be either a broken belt or a surface mount fuse has failed. If the unit is dead/unrepairable then breaking it apart carefully is the only option to retrieve the CD.
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,286
    +7,407
    Can you see any of the disc with the top off? If so, try manoeuvring it with something like a wooden kebab skewer to see if it's slipped out of the tray.
  5. pete1866
    pete1866
    Oct 25, 2004
    905
    28
    +53
    U can see an eight of the disc, it’s in the tray perfectly.
    I’ve tried forcing it eith small screwdrivers it’s very tight.
    It’ll still play the cd and the radio so I’m not going to break it to get cd out.
    If it was a broken belt, I thought I would be able to hear the mechanism trying .
    I can post a pic when back at hone
  6. dannnielll
    dannnielll
    Sep 16, 2017
    2,206
    113
    ireland
    +931
    There are a variety of different tray release mechanisms, in some a little hole forces the tray motor to engage. In others e.g the panasonic dvd player there can be a slot below which can be mechanically moved to force the action... It's a better Google question.
  7. pete1866
    pete1866
    Oct 25, 2004
    905
    28
    +53
    There is no hole and I’ve been on google.....
  8. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
    The Drawer is not going to pop out the way it does when it is working. Likely there is some kind of gear (multiple gears) and motor mechanism. You will likely have to spin the gears and make the draw creep out a bit at a time.
    It is possible that a belt is broken or worn. It is possible that a gear is stripped. It is possible that the mechanism is simply jammed. I think I had this on a BluRay Player, and while I tired to find a replacement belt, in the end I was able to clean the existing belt and put some belt dressing on it, and it started working again.
    So, you have to Trace the draw-open mechanism until you find a point where you can manipulate it and slowly work it open. Generally in the area of the drive motor that opens the drawer.
    Then look for belts that might have slipped off, or be stretched or worn. Alternately look for gears that might be stripped or dislodged. It is also possible that the motor that drives the tray open and closed has dried out and frozen. It might be possible to revive the motor by cleaning the shaft bearings with some alcohol, then simply lubricating the shaft with some fine oil.
    Steve/bluewizard
  9. larkone
    larkone
    Apr 21, 2006
    4,384
    134
    North Essex
    +1,254
    You will soon get bored of listening to the same CD over and over.
    Service Manual here DENON RCD-M39 SERVICE MANUAL Pdf Download.
    Looks like the opening mech uses a belt. If you hear nothing when the eject button is pushed then the possible are, either the button is defunct, the electrics/relays/fuses controlling the motor have failed, the opening motor has failed or the belt has failed and is jamming the motor. If you can hear the motor it is more likely just a belt failure.
  10. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,286
    +7,407
    P.12 shows the manual tray release on the base of the unit.
  11. dannnielll
    dannnielll
    Sep 16, 2017
    2,206
    113
    ireland
    +931
    ..that is the type of mechanical release i was expecting..... Move a plastic knife or a screwdriver with the power off., We don't want a funeral here.
  12. Rachel H
    Rachel H
    Jun 30, 2018
    87
    uk
    +38
    Is this a good time to mention that this would never happen with a record player? :p
  13. dannnielll
    dannnielll
    Sep 16, 2017
    2,206
    113
    ireland
    +931
    No.
  14. larkone
    larkone
    Apr 21, 2006
    4,384
    134
    North Essex
    +1,254
    But record players are rubbish at playing CDs
    • Funny Funny x 2
    • Like Like x 1
    • List
