Denon Speaker Terminals Banana Plug Issue!!
bolder01
Hi all,
I have just taken receipt of my new Denon 2808 and can't seem to get a banana plug into the speaker terminal on the back of the amp. Am i being a plum or does this amp not accept 4mm banana plugs??
Any help greatly received!
Kind regards,
Matt
Tone-uk
Have you removed the plastic inserts? Yamaha receivers come with them - maybe denon too? These are hollow- so difficult to see! To remove use a small screw and twist it in. Then pull out the bungs.
DodgeTheViper
Denon's do have the plastic plug inserts, and are easily removed as already said.
A small flat screwdiver does the trick as well, one of the small jeweller type screwdrivers.
Swissceramic
Er... Had my denon pma350 amp for 20 years and never knew about this, I always looked for thinner speaker plugs! Will try when I get home
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
