Denon speaker connections
Discussion in 'AV Receivers & Amplifiers' started by RohanM, Oct 4, 2004.
Tags:
  1. RohanM
    RohanM
    Jun 4, 2004
    350
    London
    +27
    Whilst my order for a 3805 was being processed, I measured my room up, etc, and got the relevant lengths of speaker cables made by a dealer. I also got them to terminate all the cables with banana plugs - especially as, as per my exisiting front B&W 603s, I opted to bi-wire all the surrounds.
    Imagine my horror when the 3805 finally arrived and there appears to be black plastic 'inserts', where the banana plugs should be inserted in the terminators... :eek:
    Tried scraping out (don't laugh!) with a Stanley knife on one the zone 3 outputs (which I won't be using, so thought I'd do a trial run there!) but... :thumbsdow
    Short of cutting off the plugs and using the bare speaker wires, any ideas??? :lease:
    As it is, I've got all the kit, but can't use it at the mo'...
  2. 12 promises
    12 promises
    Aug 18, 2004
    1,549
    2
    dunfermline
    +116
    I Have The Same Problem,i Have Kimber Kable And They Were Terminated With Bananas But Had To Slice Them Off And Now Have Them Connected With Spades. The Other Alternative Is To Bare End Them. It Was A Bit Unexpected When I Discovered That The Posts Would Not Accept Bananas Since Every Review I Read Did Not Mention It!!!!
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    This thread should cover all you need to use banana plugs with the Denon receivers including the 3805.
    Mark.
  4. RohanM
    RohanM
    Jun 4, 2004
    350
    London
    +27
    Cheers! I'll have a go with a jewellery screwdriver when I get home tonight... :)
