Denon speaker cable hell
Discussion in 'AV Receivers & Amplifiers' started by HappyLad, Aug 19, 2004.
Tags:
  1. HappyLad
    HappyLad
    Picked up a Denon 3805 on the way home from work this evening. Got it home, out the box and began to cable the thing up.
    Arghhhhh. The speaker terminals won’t accept banana plugs. :mad: :mad:
    What a palaver, I had to take the plugs off all my cables and start trimming the cables to fit in the binding posts. The whole thing looks a mess!
    I hate bare wire connections! It makes things a right pain when trying to make any changes to the installation and there’s a greater risk of causing a short from stray cable filaments. It wouldn’t be so bad if the binding posts on the amp were of a decent quality, but they aren’t. Once I had a few cables in I was finding it hard to actually screw down the binding posts due to the cables being in the way! :thumbsdow
    Any of you folks know how I could get the amp to accept 4mm banana plugs???
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    The 3805 does accept 4mm banana plugs. All you need to do is remove the little plastic inserts that are blocking the plug's entry. Honestly I really do wonder where common sense has gone these days.
  3. pcavelle
    pcavelle
    Jan 23, 2001
    986
    London
    +16
    Actually Crusty it's not that easy. I got a 2805 & had the same problem. Even with thin nosed pliers it's nigh on impossible, in fact in my case it is impossible, to pull the bloody things out.
    Any suggestions as to what will get them out?
    Paul
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I'm told a corkscrew would do it, just screw through it as if you were pulling a cork!
  5. pcavelle
    pcavelle
    Jan 23, 2001
    986
    London
    +16
    I'm looking at them now & can't see that one working...
  6. Arcangel
    Arcangel
    A small flat head screwdriver. Just pop them out. :)
  7. HappyLad
    HappyLad
    Hmmm.
    I can't see any inserts at all. The speaker terminals have a hole in the end, but this seems to be filled. There is no insert protruding that I can take out.
    Bugger!! :mad:
  8. Arcangel
    Arcangel
    That's what you have to pop out. Try a small screwdriver and just lever them out gently.
  9. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Point of a Stanley knife does the trick ,its a saftey feature for Europe apparently !!!!
  10. Lostinapc
    Lostinapc
    how gutted are you, happy lad!
    hehe
  11. HappyLad
    HappyLad
    Not gutted anymore - thanks to the help here I've managed to get the inserts out. Used a flat blade jewelers screwdriver I had :thumbsup:
    Now all I've to do is fit the banana plugs back onto all my cables :thumbsdow
  12. cwoj
    cwoj
    to be honest your better using a electric screwdriver and drill them out slowly...worked for me :D
  13. HMHB
    HMHB
    Nov 11, 2001
    27,188
    Nottinghamshire
    +6,125
    I must admit that this baffled me when I first got my 3805 :blush: I think I was a little afraid of breaking something by shoving a screwdriver down the speaker terminals. But once I was sober I did it in 5 minutes ;)
  14. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    It's a bit like February 29th and doesn't come around that often :D
  15. HMHB
    HMHB
    Nov 11, 2001
    27,188
    Nottinghamshire
    +6,125
    Hic .... I don't know what you mean :beer: [​IMG]
