denon setup
Discussion in 'AV Receivers & Amplifiers' started by killer10971, Jan 29, 2005.
Tags:
  1. killer10971
    killer10971
    Dec 29, 2004
    1,021
    +29
    hi
    i have just got the 2105 and used the autosetup , when i go in to the speaker config settings its saying the centre speaker is small (its not) and when i try to change it all i have is the option for none and small
    can you edit the profile its created or will i have to run the autosetup again and change that speaker before saving
    ps i have read the instructions and cant find it
    many thanks
  2. Jase
    Jase
    Mar 16, 2001
    9,402
    South Coast
    +856
    Has it set the front left and right to small as well by any chance? If so, then you won't be able to set the centre as large. The speaker size relates to the bass extension capability not the actual physical size of the speaker. No point sending bass info to a speaker that can't actually produce it when you can have it redirected to a speaker or subwoofer that can. :)
  3. killer10971
    killer10971
    Dec 29, 2004
    1,021
    +29
    yes your right
    i have small front speakers but a large centre
    changed the fronts to large and then have the option to change the centre to large (i have left it all set to small)
    many thanks
