denon set up??????
Discussion in 'AV Receivers & Amplifiers' started by barrykil, Mar 16, 2002.
Tags:
  1. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    Silly question, forgot how to get set up menu on tv screen i have a link from video out at bottom of denon amp- video jack on front of tv tosh 36zp. Got it working once but cannot for the life of me get the menu up again would be grateful for any advice
    THANKS
  2. bob007
    bob007
    Monitor out on amp > TV AV.......either s-video to scart,
    or s-video to s-video, select AV channel you have connected too. press set up on remote.
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    1. Make sure that you are using the VIDEO MONITOR OUT 1 jack and not 2 jack – OSD is not output from this jack.
    2. Make sure also that the Video section is not turned off – hit the VIDEO ON/OFF button and ensure that VIDEO ON is flashed up on the display. Similarly, don’t try and activate the SETUP menu while running PURE DIRECT mode as this turns the video section off too.
    Mark
  4. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    Thanks for your help bob007 and MarkB problem solved forgot to select monitor out channel. DUMMY.
