Denon set-up menu on Panasonic plasma
John G
I have a Denon A1SE and a Panasonic plasma (charcoal) and am not sure how to access the setup menu.Would it work if I tried an S Video lead and selected AV input on the plasma.Any help much appreciated.
Regards,John
B
bob007
The on screen set up menu can be viewed by connecting to the monitor out on the rear of the amp to the TV via S-Video, then selecting the appropriate AV channel. You can also access the osd via composite (single phono), but as I'm not familiar with the connections that are available on plasmas I couldn't say if this was another option for you. Worth checking as most folk will have a spare phono lying around, saves spending out on another lead. :)
MarkE19
I have a Panny plasma and a Denon 3802.
I have a single phono from monitor out to AV in on plasma (could have also used S-Video as both connections are on amp and plasma)
Set plasma to AV input and switch on the OSD/setup menu on amp.
