Denon seperates question UD-MR31 Receiver and DRR-M30 tape cassette
sib121
HI, can i mix these two seperates, the UD-m31 receiver I have goes with the DRR-m31 cassette player but the cassette deck is broken and I've seen a DRR-m30 cassette player i can buy , will this work
does anyone know the difference between the drr-m30 and drr-m31 cassette player
Thank You
RBZ5416
It will be fine. Google should throw up any spec differences but they will likely be minor. IIRC, the difference between the UD-M30 & 31 was tiny & I expect the same for the cassette decks.
Edit
I can see no obvious difference in the lmited specs here:
DRR-M30
DRR-M31
