Hi all..
I've been doing quite a bit of research lately.. and have come down to finding two quite good deals.. Now the only problem is I can't decided which to get!
I found the Denon SD500 and the Panny HT1500 both for £399
Obviously the Denon has had lots of rave reviews on here, but the Panny has DVD writer and Hard Disk Capability..
I know most will say it's down to what's important to you yada yada.. but was wondering if anyone has any advice, or knows a bit about the two models? For instance..
Is the DVD writer technology worth it at the moment?
Is 80Gig big enough these days, and is it a must have on todays DVD players?
Is the Denon far superior in quality to the Panny?
Should I maybe be looking to take up a cheaper option (Panny 520 at £150 or Tosh) as a stop gap for if the others come plummeting in price?
Would appreciate any comments or info on any or all of the above if you've got some time!..
Appreciated..
Appreciated..
