Denon Restorer
MysticKatDaddy
connect my laptop to the front of my 2308CI Receiver via a digital optical connection to the front input. Is there a way to automatically turn the RESTORER on when using this input?
Jase
Denon's will usually remember the last mode/settings used for a particular Input so as long as you don't change anything it should be the same when you next use it. In this case, is it switching the Restorer off?
MysticKatDaddy
That's good to know. I've actually decided to skip using the restorer as a free plugin for Winamp called DFX actually makes the compressed music sound better than the restorer function.
