Denon Reciever - not powering up.
Discussion in 'AV Receivers & Amplifiers' started by tdun, Jun 25, 2005.
Tags:
  1. tdun
    tdun
    I have a relatively old denon receiver:
    Denon AVR-610
    I was trying to program a new remote, trying different codes based on posts on the web. At the same time as I was pressing codes into the new remote control, the unit looked like it powered down. The usual audible 'click' could be heard and I thought I had correctly programmed the remote and it had turned off the receiver. The problem is that it now will not turn back on. Anyone have any clues out there? When I push the manual power button on and off I can feel the unit turn on but the display does not light up and no audio is played. Help....
