DENON RECIEVER DRA-365RD any info plz
Discussion in 'AV Receivers & Amplifiers' started by fender62, May 12, 2005.
Tags:
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    i have been searching for info on the DENON STEREO RECIEVER DRA-365RD
    but havent found any even there home page, does anyone know about them
    quality age watts etc. or a site with info
  2. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    I own a Denon DRA325 receiver I think the 365 is pretty much the same just a couple of generations newer. Think they are from the mid to late 90s and cost about £250 new. It is a remote controlled stereo only receiver. I believe that the 325 contained pretty much the internals of a PMA250 amp and a TU260 tuner in a single box. Very pleased with mine and have it with an matching Denon CD player.
  3. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    thanks for reply and info,bought it off ebay for a tenner mine did not have a remote are you sure mine would have come with one i wonder if i can get one for it
