Denon RC871 Driver for Windows XP ?
Discussion in 'Home Cinema Control & Remote Controls' started by tonymccandless, Jun 16, 2003.
  1. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Has anyone managed to get the software to work for the above remote control under Windows XP ?
    I downlaoded the software on recommendation from Denon only to find the driver was written for Windows 95 and doesn't work under XP.
    Anyone else out there with the answer ?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    Have you tried running the software in 'compatability mode'?
    To do this:
    right click on the icon
    select 'properties'
    select 'compatability' tab
    click the box for compatability mode
    select 'Windows 95'
    Mark.
  3. sweetmate
    sweetmate
    Aug 29, 2001
    694
    London
    +46
    I downloaded the aktis software and it works fine, but i recall having to manually install the driver for it.
    It comes up as unknown somethingorother in Device manager and I had to install the driver manually by pointing it to the Denon folder in c://program files.
  4. shoalin kid
    shoalin kid
    is the downloads at the us denon site ,ive got the same amp as tony .does it make a lot difference
  5. sweetmate
    sweetmate
    Aug 29, 2001
    694
    London
    +46
    Well it was essential to me to get the extended IR codes for the updated A1SE, and its also nice to reprogram it from a pc instead of on the actual unit.
    Yup I got the software from the US Aktis Site and it works fine.
  6. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Mark/Sweetmate
    I have tried to manually install but under Xp it does not recognise the driver as matching the hardware. Part of the problem may be the firmware version on the controller is v1.
    As far as runnign in W95 comp. mode it isn't the issue as the software works fine but the driver for the RC doesn't register therefore the software has nothing to talk to.
    I am still awaiting a reply from Denon....I won't hold my breath though.
    T
