Denon problems
Discussion in 'AV Receivers & Amplifiers' started by Clive Bird, May 8, 2003.
Tags:
  1. Clive Bird
    Clive Bird
    I can not get Denon amp (AVC-A1D) to work with composite video input. When I connect it all I get is a blank screen.
    Any Ideas?
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Have you got it set the correct Video Source Input? Just doublechecking, but have you connected a cable from the Composite Monitor Out as well?
    Also make sure the Video is switched ON.
