O
octo
Im putting together a hifi system. Planning on coupling a "Denon POA T10 Power Amplifier" and Tannoy Fusion 3 floorstanding speakers.
Dont know too much about about this kind of stuff...What do you think?
Specs....
(Amp)
(Speakers)
PERFORMANCE
Recommended amplifier power 10 -100 Watts RMS
Continuous power handling 70 Watts RMS
Peak output power 140 Watts
Low frequency response 32Hz
Sensitivity 89dB
Nominal impedance 8ohms
Frequency response 35Hz - 20kHz
DRIVE UNITS
High frequency 25mm(1") Nitro-Urethane layer damped woven polyester dome, shielded neodymium magnet assembly
Low frequency 165mm (6.5") coated multi-fibre paper pulp cone
CROSSOVER
Frequency 2.7kHz (Bi-wireable)
Type 4th order acoustic linkwitz-riley
Will this sound good?
A fast response would be great because the auction is ending in about 4 hours!
Thanks.
Specs....
(Amp)
(Speakers)
PERFORMANCE
Sensitivity 89dB
DRIVE UNITS
CROSSOVER
Thanks.
