Denon plug?
Discussion in 'AV Receivers & Amplifiers' started by LCD User, Sep 6, 2005.
Tags:
  1. LCD User
    LCD User
    Hi, just home and setting up my 1906.
    Ordered from my local dealer i open it up and only has a european 2 prong plug. Whats the deal with that. I'm not really into using an adaptor. Should I not have been issued a UK version?
  2. Jase
    Jase
    Mar 16, 2001
    9,531
    UK
    +931
    Some dealers get grey imports from Europe. Just cut the 2 pin plug off and wire a UK plug onto it. Or you could use one of those UK plug adaptors (the 2 pin plug goes up inside a standard looking UK plug).
  3. LCD User
    LCD User
    i take it the adapter will not have any effect on performance?
  4. gazza166
    gazza166
    Jul 31, 2003
    767
    Plymouth
    +23
    If you're worried about performance then you could fit a male IEC connector like this. That way you could then upgrade your mains lead to a shielded non-RFI cable.
  5. Jase
    Jase
    Mar 16, 2001
    9,531
    UK
    +931
    Can't say I've ever experienced any performance problems using an adaptor.
  6. jof006
    jof006
    I've just received a Denon AVR-2106 and that came with a 2 to 3 pin adapter fitted around the 2-pin plug inside.
    Either I've got a European import, or this is the way the UK models are actually shipped.
    Anyone got an AVR-xx06 with a moulded 3-pin plug?
    Update :
    Just spoke to Denon technical support and they confirmed that a UK model will have a 2 to 3 pin adapter fitted around the 2-pin plug inside.
  7. bvs
    bvs
    My 2106 came with the adapter type thing too.
  8. LCD User
    LCD User
    Yup thats what the dealer told me, just ssems they forgot to add in the 2 -3 pin adaptor. Have it now. Cheers
