Denon or Onkyo
Discussion in 'Blu-ray & DVD Players & Recorders' started by steve k, Nov 14, 2001.
  1. steve k
    steve k
    Apr 15, 2001
    713
    Birmingham
    +53
    Can anyone suggest which AV amp to go for out of these two, the Denon AVR3802 or the Onkyo TX-DS696.
    The Onkyo is only 5.1 but has 5 x130 watts per channel, the Dennon has 7 x 105 watts.
    Also it was suggested that the Kef KHT2005 speakers would go ok with these amps.
    Any suggestions welcolm.
  2. steve k
    steve k
    Apr 15, 2001
    713
    Birmingham
    +53
    Also can anyone suggest a good price Sevenokaks quoted £850 for amp and £800 for speakers
    This included coming to my house and setting it all up with all the leads & cables need.
  3. dochall
    dochall
    I've got a 3802 and the Kef Eggs which I'm very happy with both for AV and music.
    You should be able to get both for around £650 each. Suppliers have for both have been mentioned in these forums before - try the search facility.
    Of course you won't get the setup and will pay for the leads. The setup is actually very straightforward. Open a beer read the manual and away you go. If they are going to give you decent cable then it does represent a saving but not a huge one. Are they going to provide the interconnects as well?
