Denon Link vs/and HDMI
Discussion in 'AV Receivers & Amplifiers' started by fredz85, Sep 6, 2007.
Tags:
  1. fredz85
    fredz85
    May 2, 2005
    17
    Have got a Denon DVD-2930 and a new Denon AVR-4308. I use the DVD-2930 for both CDs and watching DVDs. Both are now connected using HDMI. If I connect both using Denon Link cable AND HDMI (as I still need to watch DVDs and I gather Denon Link only carries audio), will the devices choose the "best" connection automatically? Ie CDs: Denon Link / DVDs: HDMI (or HDMI for video and Denon Link for sound on DVDs)?
  2. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,250
    Use HDMI for Video and Denon Link for audio. You can't use both for Audio. It has to be one or the other.
  3. fredz85
    fredz85
    May 2, 2005
    17
    Yes but can I select this on the 2930 or on the 4308? Or do I need to unplug every time?
  4. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,250
    If you wanted to keep switching back and forth then you'd need to keep re-assigning both the 2930 and 4308. Audio via Denon Link is superb and it passes all the formats (CD, Dolby/DTS, SACD, DVD Audio) so you'd be better off just using that.
  5. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    It has to be manually set in both player and amp.
    It may not matter but from the player you won't get SACD over HDMI.
