Denon Link Problem
Discussion in 'AV Receivers & Amplifiers' started by toonarmynufc, Aug 25, 2005.
Tags:
  1. toonarmynufc
    toonarmynufc
    I Have A Denon A1sr Amp And A 3910 Dvd Player When I Connect The Dvd Player And The Amp Via Denon Link The Lock Indacator On Mt Amp Flashes On And Off .the Sound Come And Gos Any Ideas Chaps
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,435
    United Kingdom
    +1,813
    I assume you've checked the cables in the socket properly?
  3. toonarmynufc
    toonarmynufc
    Yes Ive Checked The Cable 2 See If Its In Right
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,435
    United Kingdom
    +1,813
    Does it do this for all signals or is it something specific e.g DVD Audio?
  5. toonarmynufc
    toonarmynufc
    all signals
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,435
    United Kingdom
    +1,813
    The Denon Link socket on the A1SR is marked as Denon Link S.E (or Denon Link 3 if the Amp is the A1SRA) isn't it?
  7. toonarmynufc
    toonarmynufc
    my amp is a a1sr not a a1sra
  8. S H A D O
    S H A D O
    Mar 16, 2001
    10,435
    United Kingdom
    +1,813
    Does the Denon Link have a little S.E sticker next to it??
  9. toonarmynufc
    toonarmynufc
    nope it just says denon link on the back of the amp.on the dvd player it has 3rd i think the dvd player mite be dodgy
  10. S H A D O
    S H A D O
    Mar 16, 2001
    10,435
    United Kingdom
    +1,813
    That's your problem. Denon Link is NOT compatible with Denon Link S.E or Denon Link 3. You need to have your Amps Denon Link upgraded. Your DVD player is fine.
    Denon are offering an upgrade for the A1SR to A1SRA spec which includes Denon Link 3, HDCD and Dolby PLIIx. Best bet is to contact them and ask when this will be available for the UK (Denon Germany have been doing it for a while now). You'll have to pay for the upgrade though, if I remember correctly it's around 250 Euros (170 quid).
  11. toonarmynufc
    toonarmynufc
    cheers i will have 2 do that then
