denon link cable
Discussion in 'AV Receivers & Amplifiers' started by HAL 2007, May 2, 2007.
Tags:
  1. HAL 2007
    HAL 2007
    Apr 26, 2007
    hi all I have a denon 3910 dvd and a 3805 amp but have lost my denon link cable dose anyone no where I can get a replacement from ?
    T.I.A
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,930
    2
    The Fylde Coast
    +13,680
    Apparently you can use shielded Cat5 or Cat6 network cable at the fraction of the cost of a Denon Link cable!
  3. chrissb6
    chrissb6
    Dec 26, 2003
    45
    U.K
    Yes a cat 5 or 6 cable will do the job:thumbsup: . I had the very same problem:rolleyes: check my thread from a few weeks back, Denon forum came to the rescue, don't get sucked into a buying a top dollor replacement, mine cost a fraction from Maplins:)
  4. Peter Galbavy
    Peter Galbavy
    And Maplins is a rip-off in turn for patch leads... but if you are buying just one then that shouldn't matter... A "bulk" 2m STP patch lead should cost about £1 - £1.50 from most network cable suppliers, but by the time you add minimum order / delivcery charges, you will be matching the £6 - £10 you pay at Maplins.
    Don't even get me started about the Dixons/Currys/Comet rip-offs!
  5. keithlewin
    keithlewin
    Jan 18, 2006
    193
    19
    Witham, Essex
    +6
    You need to make sure the Cat 6 cable is properly shielded at the actual plug ends. If it's just plastic you can see it won't work as the Denon uses the copper "cap" for earthing (so the guys at Denon tech support told me). The Cat 6e cable is actually better than the ones they ship with the Denon 3910 which is very basic indeed.
