Denon Link cable?
Discussion in 'AV Receivers & Amplifiers' started by x5tjf, Apr 19, 2005.
Tags:
  1. x5tjf
    x5tjf
    Apr 13, 2005
    77
    +5
    The Denon Link cable that is used to connect the digital audio between a DVD3910 and an AVR3805 for example. Is this supplied with one/both of the units or does it need to be purchased separately?
    If I need to buy one afterwards, can anybody point me at the correct item? I did a search but could not turn up anything on the web :confused:
    Thanks,
    Terry
  2. Cwhelan
    Cwhelan
    Jan 29, 2005
    144
    Milton Keynes
    Terry,
    My 3910 came with one, however my AVR 3805 didn't?
    Basically it is a CAT 5 cable I've been told, not sure if it is just a patch lead or a crossover lead though - you would need to check.
    My local Sevenoaks dealer said he would get one for me from Denon if one wasn't included in any of my boxes, luckily one was.
    Conor.
  3. x5tjf
    x5tjf
    Apr 13, 2005
    77
    +5
    Thanks for the quick response Conor :smashin:
