Denon Link 3rd Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by rszee, Jul 2, 2005.
  1. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    Just got my DVD 3910 back with Denon Link 3rd but the set up menu has only 2nd.
    Has anyone else have a denon link 3rd enabled 3910
    I had the player multi regioned and i think this may be the cause of the problem
    I checked the firmware 6609-B
    Does anyone have any ideas
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I didn't think there was any firmware out there that supported both multiregion and Denonlink 3rd just yet. My understanding is until you get a multiregion version of the firmware that supporst Denon 3rd, you can only have one or the other.
  3. Timbo21
    Timbo21
    Dec 23, 2004
    4,473
    3
    2
    London
    +263
    Yes, this is what I was told by 7oaks just after the man had attended denon
    meeting.
  4. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    Thats sounds about right for denon, I expect no different so I will have to wait for another firmware update. (I thought I could get rid of all those leads!)
    I have to have MR because 1/2 my DVD's are region 1 or 3
    bugger
  5. mik
    mik
    Dec 11, 2002
    147
    +9
  6. MPK
    MPK
    Nov 26, 2004
    479
    London
    +8
    I have upgraded my firmware a few days ago to DL3 MR. On your menu you will then find under Denon Link 2nd AND 3rd. If you pick 3rd your SACD will work fine via DL.
    Obviously, you have been duped regarding the 3910 with DL3. Check out this thread on how to update your firmware to 6609-9B with DL3 and MR. However, this takes a certain amount of courage as for some people the self-update fails, which means shipping the unit back to Denon...
