Rapidmagic
Hi all,
I'm using Denon AVR-X2600 as a home cinema setup with Heos 250 speaker in a separate room.
I really enjoy using Airplay over home wifi with iphone/ipad with multiple rooms selection and separate volume control ect
The practicality and ease of use works for me.
I have a pair of great old Tannoys speakers and was thinking to buy Heos HS2 amp to add another room to the set up.
Anyone used Heos HS2 amp? Is this any good?
I was looking at alternatives but all I could find is Denon DRA800H with build in Heos but then I'll be using AVR just to power two speakers when it's all about connectivity for me.
Thanks for the help.
