Denon fatory reset - how?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hi_robb, Dec 18, 2003.
  1. hi_robb
    hi_robb
    Hi folks,
    anyone out there no if there is a procedure for resetting a Denon dvd player? Like a hard boot if you might call it that?
    eg: hold play + fast forward and switch it on!
    I would like to reset mine back to factory defaults if poss.
    Dave
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Which one have you got?
    Ian Guinan
  3. hi_robb
    hi_robb
    I''ve got a 3800.
    Tia
    Dave
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Check out the firmware upgrade instructions on my FAQ (see my sig) - this has the procedure for how to "INITIALISE" the player. This should reset the settings...
    6) Initialization: Turn off the power once, and then turn on again. While holding the
    "SKIP FORWARD" (>>|) and "PLAY" (>) buttons simultaneously, press the "OPEN/CLOSE" button for
    longer than 3 seconds until the display reads "INITIALIZE".
    JJ
  5. hi_robb
    hi_robb
    Jason,
    Many many thanks m8y :)
    Dave
