denon F07
Discussion in 'Hi-Fi Stereo Systems & Separates' started by paulcal69, Feb 24, 2013.
  1. paulcal69
    paulcal69
    Feb 24, 2013
    4
    Hi I just dusted down my old denon F07 separate system ( tape,cd,tuner&amp).
    Theres an aux port on the pack which is red&white connectors, is there a way i can play my iphone through it? thanks
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,128
    +7,284
    A cheap 3.5mm to phono cable in the headphone socket if you're not too worried about quality or a more expensive dock/DAC that takes a digital signal from the iPhone if you are.
    The quality (bitrate) of the music stored may be a limiting factor though.
  3. paulcal69
    paulcal69
    Feb 24, 2013
    4
    Thanks:thumbsup:. its a 1/4 jack so ill get an adapter that size. would a splitter that goes into the back red/white aux socket work also?
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,128
    +7,284
    Sorry, what's a 1/4 inch jack? I'm sure the iPhone will be 3.5mm so one of these or similar would do the job.
  5. paulcal69
    paulcal69
    Feb 24, 2013
    4
    The 1/4 inch is what the denon has. so i need a 1/4 to 3.5mm convertor
  6. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,128
    +7,284
    When I said connecting to the headphone socket, I meant of the iPhone. So you have a cable with a 3.5mm jack in the iPhone's headphone socket going to the red/white phonos on the back of the Denon. A 1/4 jack input would be very unusual. I've had a quick look at Google Images & can't see any sign of one.
  7. paulcal69
    paulcal69
    Feb 24, 2013
    4
    :blush: gotcha, now i understand what you mean.thanks for sticking with me on that one. Ill buy one and let you know how it goes.
