Quantcast
Denon DVD3800 RGB=>Component Passthru
petertully
Anyone know if it's possible to pass a Sky signal to the RGB (in) scart socket on the Denon 3800 and for the output signal to come from the Component RGB, to hook up to plasma.
I've been fiddling around with it, but can't seem to get it to work!? There could be a very good reason why...it's impossible!
Any feedback greatfully received from esteemed members.
SamirP
From What I can remember the scart on the 3800 is RGB output only ;)
The other option is to use a rgb to vga converter then you could use the vga input on your plasma
SamirP
Or you could use a rgb to component converter connected
to your amp and use the component switching
petertully
Cheers, looks like the converter is the way to go.
Similar threads
