denon dvd2900
Discussion in 'Blu-ray & DVD Players & Recorders' started by PAUL RODGERS, Sep 14, 2003.
  1. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    just bought a denon dvd 2900 because it was pal progressive scan, when using on my L&G MZ17 plasma the picture is jumpy, can anybody help because it is driving me insane ( DENON SAY MY SCREEN IS NOT COMPATIBLE) :confused:
  2. robbster
    robbster
    Jul 20, 2003
    394
    +13
    Hi Paul
    Is the LG plasma displaying NTSC progressive scan ok? I have this player hooked upto a hitachi 42pd3000 plasma screen and PAL progressive works ok. I think denon might be right and you screen is not compatible unfortunately.
    Rob
  3. laurie
    laurie
    Nov 23, 2001
    145
    16
    Sydney Australia
    Well you can first try it with S-Video or turn the progressive scan off if its possible like my Denon 2800!
    cheers laurie
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    You screen may not work properly with progressive PAL (UK DVDs etc), but it may work ok with Progressive NTSC (american DVDs etc). Try it in interlace mode.
  5. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    CAN I CHANGE THE DENON INTO NTSC PROGRESSIVE MODE
    THANKS
  6. robbster
    robbster
    Jul 20, 2003
    394
    +13
    You could force the DVD player to output NTSC only. You do this by going into the DVD menu and setting it there. Only problem is that PAL material doesnt play too good (a bit jerky). Other than that just turn off the progressive output on the DVD menu and have it interlaced for both NTSC and PAL
  7. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    Denon dv 2900 can play both Pal and Ntsc progressive scan, the only way you can output NTSC progressive scan is by play NTSC software, if you play a PAL video it will out put PAL progressive scan. So when playing region 1 discs use progressive scan and when playing PAL software use Interlaced.
