Denon DVD2200 - Power button
Discussion in 'Blu-ray & DVD Players & Recorders' started by daveb975, Oct 14, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,357
    103
    London
    +371
    I have just got a Denon DVD2200.
    All seems fine, except for the fact the power button seems a little loose. When turning it on, it sometimes gets stuck in, before popping back out again.
    The button is one of the on/standby ones, so can be left on all of the time, and then the player can be 'soft' powered up/down by the remote buttons.
    Given that I will not be using the power button all of the time, does this sound like it will be an issue. Is it something that is worth sending the player back for?
    Could anyone else who has a 2200/2900 confirm if theirs is the same?
    The 2910/3910 seem to have completely different design of power buttons - perhaps this is why?
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,109
    2
    In a secret location with Jennifer Lawrence
    +9,995
    Don't think they would have designed it to be loose like you describe, if its easy to do, just take it back to where you bought it from, or give them a call.
    I have a 2900 but it must have a different design to the 2200. Its either off or standby, with the remote changing it from standby to full on.
  3. daveb975
    daveb975
    Oct 25, 2002
    4,357
    103
    London
    +371
    Sounds as though the 2900 similar to the 2200. When the button is out, the player is fully off, when it is in it can be toggled between 'on' and 'standby' by the remote.
    When pushing the button in, it seems to snag against the casing slightly, beofre popping into position.
    If I leave the button in, and plug it in at the wall, the player goes straight into 'on' mode, not 'standby'.
  4. Mr Forgetful
    Mr Forgetful
    Jun 7, 2004
    377
    West Midlands
    +15
    I have the 2200 and don't have the sticking power button problem, it should be a simple push in and out jobby, i'd take it back for the shop to look at!!
  5. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I have the sticky button problem too, but found if you press it a certain way all is fine weird lol
  6. daveb975
    daveb975
    Oct 25, 2002
    4,357
    103
    London
    +371
    I have found that now too. If you push the left of the button it is fine, push the right side it sticks slightly.
    I am used to it now!
