Denon dvd1910
Discussion in 'Blu-ray & DVD Players & Recorders' started by Throttle, Oct 17, 2004.
  1. Throttle
    Throttle
    Sep 28, 2004
    1,827
    Leigh
    +108
  2. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    hi there,
    I have just come back from singapore and purchased a GOLD 1910,so far have just tested via component.Picture is very good and on a par with my arcam88+ :eek: And i only payed $450(singapore dollars)=:D
    Cant wait to test the dvi output when i get round to getting a board for my panny!!
  3. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    eBury, can you tell me what the 1910 is like build quality wise? I would imagine it doesnt compare with the Arcam?
  4. mojomanic
    mojomanic
    Hi Ive had a 1910 for 10 days now and have it connected to an Infocus 4805 using
    the DVI output. Picture quality is stunning, before buying I demoed it with the 4805 and also demoed a 2200 ( this one via component,it has no DVI )I couldnt see any noticeable difference in picture quality.The 2200 is more expensive and shows in build quality but the 1910 has a decent facia and looks fine in my equipment rack. I would recommend it highly!!
  5. Throttle
    Throttle
    Sep 28, 2004
    1,827
    Leigh
    +108
    Thanks for the info i'll start saving up for it now :laugh:
  6. phlix
    phlix
    Sep 1, 2004
    Is it multi region .... I can't be bothered to wait until the sammy 945 comes out, so I may just buy the Denon now!!!
  7. phlix
    phlix
    Sep 1, 2004
    Where is the cheapest place to buy the 1910 from .... just I've noticed using pricerunner, kelkoo and dealtime, the cheapest price is £219.95 From HiFix. I've found it in the US for $209. Its seems very unfair that there's not even the usual $1 = £1 that usually occurs with electrical goods.
    Also can anyone recommend a good DVI cable and Coax digital cable?
