Denon dvd and amp connections?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dom Rice, Mar 27, 2003.
  1. Dom Rice
    Dom Rice
    I have a denon dvd player2800mk2 connected to my denon amp avc11sr via the component connections. The amp then ouputs component to my projector. Alls OK.
    However I have a tv that needs to be fed with a s-vid cable. My question is this :
    Can I connect the dvd to the amp with a s-vid cable as well as the component ones so that I can also watch dvds on my tv?
    Didnt want to just try it incase I shorted something.
    Advice and help much appreciated.:confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You'll need to connect the DVD to the amp by s-video as well for this to work. The amp will only upconvert and not down as far as I know.
    If it does down convert it will be fine anyway.
  3. Dom Rice
    Dom Rice
    So if I connect it as suggested it should all work ok. No chance of things going bang?
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Should work fine.
    If you get no picture from the DVD then you will need to connect the DVD by s-video to the amp also.
    :smashin:
