Denon DVD-A1XVA settings?
Discussion in 'Blu-ray & DVD Players & Recorders' started by UlrikR, Jan 5, 2007.
  1. UlrikR
    UlrikR
    Mar 6, 2005
    13
    3
    Hi guys,
    I have this fantastic player - however, I have some problems setting it up. Leaving all picture adjustments at standard yields a very dark picture with limited contrast (I use a Panasonic PT AX100 projector via HDMI). IRE is set to 0 as default.
    What settings do you use/which picture adjustment settings have you changed? Further, should I change IRE to +7.5 and adjust black level/contrast to achieve a better picture?
    I previously used a Denon DVD 3910 on the same setup and used the default picture adjustment settings and the picture had more contrast...
    Hope someone can help - thanks a lot!
    Ulrik
  2. Jase
    Jase
    Mar 16, 2001
    10,873
    United Kingdom
    +3,071
    Currently have mine with IRE set to 7.5. DVI - 720P Enhanced with the Black Level adjustment set to -2. It's worth playing around with either YCbCr and RGB (with or without Enhanced levels) and all other available adjustments to see which setting works best for you. :)
    Other settings on mine are High Sharpness -4, Mid Sharpness +2 (although this doesn't affect the HDMI/DVI output), Enhancer +2, DNR +1, CCS - ON.
  3. UlrikR
    UlrikR
    Mar 6, 2005
    13
    3
    Jase,
    Thanks a lot! Will try it when I get home and see how it works.
    Ulrik
