- Joined
- Jan 24, 2000
- Messages
- 17,040
- Solutions
- 1
- Reaction score
- 14,136
- Points
- 7,651
- Location
- Birmingham, UK
Folks, if you use a normal VGA cable plugged into the the DVI-D output (using a DVI-D to VGA adapter) of the Denon DVD-A1XV and the other end plugged into a normal computer monitor, does it work?
Is it possible to plug the Denon DVD-A1XV directly into the RGBHV inputs of a CRT projector?
