denon dvd a11
Discussion in 'Blu-ray & DVD Players & Recorders' started by DEANO65, Nov 25, 2003.
  1. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    im about to buy a a11,for the dvi connection.its going to a fujisu plasma 50" . can anyone tell me if it would be a lot better picture than my old machine {denon 3800}which was component connected and is there any thing to consider, ive done a bit of homework on this machine but any more info would be a bonus thanks
  2. Timmy B
    Timmy B
    Why not get a momitsu first?
    With the momitsu you can check out native rate on your fujitsu - they sent me the video timings if you need them.
  3. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    thanks for the advice, ill look into it
