denon dvd 800 mp3?
Discussion in 'Blu-ray & DVD Players & Recorders' started by steveoc, Jul 24, 2002.
  1. steveoc
    steveoc
    I have just brought a Denon dvd_800 .On the american website it says this model plays MP3 .Mine doesn't although I understand it is already multi-region.
    Is there anyway to enable mine to play MP3
    It has a region 2 sticker on & plays a region 1 disc so is multi region. Denon say only american models do this and won't supply anymore info
  2. Geoffc10
    Geoffc10
    You should try a pc program called MP3 cd convertor from Two cowes.com. Be warned that you have to burn all your songs at once as it finalizes the disc after all the tracks have been burned.
    Your sony should be able to play cd r or cd rw.
