Denon DVD-5000 THX-Ultra
Discussion in 'Blu-ray & DVD Players & Recorders' started by MarkB, Dec 4, 2001.
  1. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Anyone got any more info on this unit?
    Mark
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    THX Ultra Certified DVD Player • 24 bit, 96 kHz 4 DAC D/A conversion system, featuring Burr-Brown PCM-1704 DACs • HDCD decoding for HDCD-encoded CDs • Denon's Alpha 24 bit DSP audio processing system • Optical and coaxial digital audio outputs • Optical and coaxial digital inputs for external digital audio sources • Triple transformer power supply system • Backlit handheld infrared remote control • 2 Composite video, 2 "S" video and one set of component (Y, R-Y, B-Y) video outputs • Digital audio outputs compatible with Dolby Digital (AC-3), as well as dts encoded DVDs, and dts encoded music discs • Graphical on-screen display system for easy system setup and operation • 10 bit video DACs for best picture quality
    try this link http://www.denon.com/catalog/products.asp?l=1&c=57
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Cheers.
    I take it this is the model that the DVD-A1 replaces. Perhaps also the DVD-A1 will be available in the UK.
